04 crown vic wo`nt start
Thread Statistics:     Users to Post: 4   |   Total Posts: 4   |   Total Views: 720
greyghostvic
• council bluffs, IA, USA
• Registered on 6/9/2012
Posted:6/23/2012 06:17
My good deal might not be a good deal. 04 p71 new fuel pump, crank sensor, new ignition switch and 3 different SMUs still not running. Not getting a check engine lightand fuel pumpdos not run. Not sure where next to turn.
Posted:6/23/2012 06:34
Try the following link: http://www.cb7tuner.com/vbb/showthread.php?t=147239 for the Chilton manual. A shop manual would explain the steps you need to go through to find out what is wrong.
Did you try to get a scan from the OBD? I have seen people say they had no Engine Light come on, which turned out to be a burnt bulb. And any code you do get may not be what is wrong. I once had a code for a bad O2 sensor. After a Google search, it turned out to be a vacuum leak. Replacing vacuum hose, $1.20; if I would have replaced the sensor $115.
Also, try www.crownvic.net for additional help.
edited 6/23/2012 06:35
jwar1127
• lauderhill, FL, USA
• Registered on 5/28/2009
• 47 posts
Posted:6/23/2012 06:56
Do you have a pats or a security system?
ceptor1
• Huntsville, AL, USA
• Registered on 6/7/2012
• 12 posts
Posted:6/23/2012 11:02
I have an '03 Ford factory manual with wiring schematic manual if that would be compatible I might could help?
